نرم افزار رسیور ایکس کروزر مدل XCRUISER 600HD ورژن 1.99.99TO 2.09.35 بتاریخ 2016.05.05
Software Update from 1.99.99 To 2.09.35
Make sure your receiver current software version is 1.09.35
Update the receiver Software to version 1.99.99
Then Update the software version to 2.09.35
How to Update:-
Copy both Software versions to USB and Connect to Receiver you will see pop-up with Version 1.99.99
Press RED key to download after update done receiver will reboot
When receiver restart successfully window will pop-up again this time it will show software version 2.09.35
Press Red key to download again after update complete receiver will reboot and loader version will change to "Loader 6.00"
Software Release Note:-
New Features will be added and supported in near future like DLNA, 3G Modems, Full NTFS Support, and many more
Note: - Keep your receiver software up to date to enjoy the new features and improvements & stability.
Important Note: -
Once the receiver software updated to version 2.09.35
Then it cannot be downgraded to old versions like 1.xx.xx
Software ID Changer from 1.99.99_to_2.09.35
paperclip فايل هاي پيوست شده
